Author Topic: 6.5/7.2 on the same server  (Read 3954 times)
manu
« on: April 10, 2007, 12:34:58 PM »
I would like to know if it's possible to have 2 configuration on the same server with a different version of genesys (v6.5 and v7.2)?
Indeed currently we have a configuration 6.5 which functions on a server and I would like to install a configuration 7.2 on the same server.
But I don't want to migrate from 6.5 to 7.2, I need to run the both configuration at the same time.
Thanks for the responses !  :)
PS: Sorry for my english  :P
Offline Adam G.
  • Still Gorgeous.......
Re: 6.5/7.2 on the same server
« Reply #1 on: April 10, 2007, 01:11:24 PM »
  • Yes but....
    (1) make sure you have enough of the [b]correct[/b] Genesys licenses.
    (2) your DB is of a high enough spec.
    (3) the apps v6.5 v v7.2 will need to use different port numbers
    (4) your switch supports 2 TServers simultaneously.
    (5) keep the install locations separate.
    Unless this is a very small test environement, I wouldn't recommend doing what you want. Even then using the same server will be a false economy.
    manu
    « Reply #2 on: April 12, 2007, 01:13:57 PM »
  • Ok,
    Thanks for the quick response and sorry for the late thanks :P
    manu
    « Reply #3 on: April 25, 2007, 08:48:09 AM »
  • Hello,
    Why do you not recommend to install 2 versions on the same server?
    Precision : I wanna use this configuration for a test environment with no physical switch.
    Manu
