Author Topic: non working cisco phones on Genesys platform  (Read 5735 times)
daxvancamp
« on: April 06, 2007, 08:39:56 AM »
I have 4 cisco phones 7960 which I want to test.
They wee previously tested but with dummy ID's.
I decided to change the ID's ( places and acd positions ) so that we can start doing the necessary tests.
Guess what, they don't work anymore :-(
I can't find anything special and when I test with our current IP phones ( SNOM ) I don't have any problem at all.
I think I'm missing something ( like an option somewhere ).
this is configured: on the place/dn -> sip:@ipaddress:5060 ( missing backslashes because the forum thinks it's a link )
Re: non working cisco phones on Genesys platform
« Reply #1 on: April 12, 2007, 06:53:10 AM »
  • daxvancamp (wheew!!! It was hard to type!!! I should have used CTRL-C/CTRL-V :-[)
    here is how I define our IP phones (we usually need to specify what DN they are in the sip: option) like this:
    [attachimg=#]
    daxvancamp
    « Reply #2 on: April 12, 2007, 08:15:44 AM »
  • This is how it's configured at our site:
    « Reply #3 on: April 12, 2007, 03:57:40 PM »
  • ? I don't think that will work as you show us. Victor config is the correct.
    daxvancamp
    « Reply #4 on: April 13, 2007, 01:15:47 PM »
  • Well,
    It's kinda different here.
    We don't register the phones and this configuration works fine for our other phones, SNOM320 and SNOM360.
    There is only a mapping of a place to an IP address in our Genesys system ( this was setup by our integrator ).
    daxvancamp
    « Reply #5 on: April 25, 2007, 06:05:20 AM »
  • The CISCO phones are working now.
    I knew it was a parameter missing but couldn't remember which one !
    Our support contacted a specialist and he figured it out.
    This is how the ALIAS part is configured for our SNOM phones sip:@ip_address:5060 ( 2 missing / as i'm not registered -> url)
    which work fine
    This is how it should be for CISCO phones sip:ID@ip_address:5060 ( 2 missing / as i'm not registered -> url )
    It seems taht it's necessary to add an ID in front of the @ for CISCO phones.
    The specialist recommended to add the ID for all configurations ( CISCO and SNOM ) like it should be.
