Author Topic: Quest Server beta testing  (Read 14465 times)
« on: April 03, 2007, 05:25:17 AM »
Ok, guys,
we got a beta version done and finished with.
Now it is up to you to test and get back to us with the comments.
The only thing I am worried is about documenting how to set it up (there is a config.xml file that needs to be setup)
so if there is a brave sole out there willing to re-write the setup document for me, it would be greatly appreciated.
Best regards,
Re: Quest Server beta testing
« Reply #1 on: April 03, 2007, 06:29:48 AM »
I am enclosing a sample questClient.HTM file used by QuestClient.
Note: it will be a use to you only if you have installed QuestServer and have QuestClient.ocx . Without it, this file will not work.
« Reply #2 on: April 09, 2007, 05:23:09 PM »
What i need to get access to the files? went to download section and can't see anything. Tought might be attached to some post but nothing. I'll like to test it and help.
Offline Haldane
« Reply #3 on: April 12, 2007, 05:26:50 PM »
Same as, Would be happy to test. We have some test plasma's and LED screens we can use....
Schrage
« Reply #4 on: May 15, 2007, 05:22:32 PM »
Is this still available?
« Reply #5 on: June 06, 2007, 05:29:55 AM »
The main problem we are having right now is that it is still in Japanese.
If someone wants to help me translate it into bearable English, it would be great!!!
Volunteers?
« Reply #6 on: June 08, 2007, 03:03:03 AM »
I tried to but my VB is showing only strange characters instead of Japanese symbols. Maybe some screenshots may help or how to make my VB show japanese symbols.
« Reply #7 on: June 08, 2007, 07:39:15 AM »
Yeah, probably that's because it does not support them.
Ok, I will try to get something...
