Author Topic: Genesys Voice Platform (GVP) connection via T1 to Siemens HiCom 300 switch  (Read 4073 times)
rosshartford
We are attempting to connect a GVP box via Dialogic to a Siemens HiCom 300 switch.  We have it configured as T1-Robbed bit on the GVP side and have tried both loop start and wink start in the VPM configuration, with no luck.  Does anybody out there have a configuration for both the GVP side and the Siemens side that they would be willing to share?
Thanks!
Ross Hartford
I don't have Dialogic with our GVP (we use SIP), but if it will help you, I can email you our GVP config.
Marked as best answer by on January 31, 2025, 01:15:27 PM
rosshartford
Well we got it working.  Below is the Siemens switch configuration.  BTW, use the pdk_us_ls_fxs_io configuration in the VPM setup.
| DETAILS OF TMD BOARD AT ADDRESS (LTG.LTU.SLOT) = z. y. xx
|    CABTYP =    3      TIMTYP = SYST       SIGTYP = CAS
|     FRAME =  STD        TABS =   NO       FCTID  =   1
|    BI8SUB =   NO      BIVDET =   NO
|   RDRATIO =     6       RDTH =  2500      RDQUAL = 15000
|    YLSEND =  5000       YLTH =   400      YLQUAL =   100
|       LOS =   150        AOS =  4000
|  SESDISTH =    10   SESREQTH =    10
|  OESDISTH =    30   OESDISIN = 24-00-00
|  OESREQTH =     4   OESREQIN = 04-00-00
|    NETUSR =           ACKTIM =            DLVTIM =
|    OCTMAX =           RETMAX =            WINDOW =
|    CRIDC  =           TTSC   =            NSFIV  =
|    NSFTSC =           PFDGT  =
|       IGN =            IID =
