Author Topic: "Hard phone" wrap up time  (Read 4504 times)
J.Smith
« on: March 21, 2007, 03:48:12 PM »
Hi everybody!
Does anybody know how to modify the wrap-up time for a hard-phone? There's any parameter in the T-Server to modify it?
I've that question because some of our agents are using a custom soft-phone where we can modify that after-call-work time, but some other are working directly on the phone, and they think that the time they have is a lot.
Thanks a lot!!
Re: "Hard phone" wrap up time
« Reply #1 on: March 21, 2007, 04:47:36 PM »
  • Uh?
    Which PBX are you using?
    On each agent on CME there is a wrapup time option.
    Also on the TServer but for some kind of agents (emulated).
    Those agents that use a softphone must log on somewhere, a sip phone? a hardphone? How is their Wrapup (ACW) time handled?
    J.Smith
    « Reply #2 on: March 21, 2007, 10:06:24 PM »
  • Hi!
    The PBX we are using is an Avaya.
    We've tried to modify the wrap-up time option for agents and the T-Server parameter, but in hard phones, the time for wrap-up seems not to vary :(
    Thanks!
    Offline Fra
    « Reply #3 on: March 21, 2007, 10:27:09 PM »
  • If you are not using any agent desktop for those agents, Tserver can't help you...  ;D
    To my knowledge for an Avaya switch the only thing that may help you is the TACW - Timed After Call Work - that puts the agent into the ACW state after an ACD call; when the configured timer has expired, puts the agents back into the ready state.
    Note that this is NOT configured on the phones, but on the VDNs/hunt groups the call passes through.
