" /> Creating agent information without the sdk. Is it Possible? - Genesys CTI User Forum
Author Topic: Creating agent information without the sdk. Is it Possible?  (Read 2571 times)
KP
« on: March 13, 2007, 08:22:21 PM »
Is there a way to create an agent within the system with out the use of client sdk. ie through database or command line options...
thanks
Offline Adam G.
  • Still Gorgeous.......
Re: Creating agent information without the sdk. Is it Possible?
« Reply #1 on: March 13, 2007, 10:15:10 PM »
  • Simple answer - No.
    It is probably posible to do it with some SQL but then you'd have to bounce the Config Server. This has the potential to corrupt your DB and thus your whole config. My advice is just don't even try as Genesys probably won't support you if it all goes wrong.
    Pavel
