" /> Custom stat threshold - Genesys CTI User Forum
Author Topic: Custom stat threshold  (Read 2687 times)
Offline sy278
« on: March 09, 2007, 02:11:25 PM »
Hi Guys,
I have two stats, Total calls entered and total calls Force disconnected, these stats are formed by DN Groups, is there anyway I can create a threshold to apply a colour to the number of force disconnects when it is a certain percentage of the total calls entered?
Offline catanirex
Re: Custom stat threshold
« Reply #1 on: March 09, 2007, 02:38:45 PM »
If you add a new stat in the CCP template using the formula Total calls entered/total calls Force disconnected, the you should be able to add thresholds on the new stat when it is above/under your limit.
Hope this helps!
Offline sy278
« Reply #2 on: March 09, 2007, 02:50:46 PM »
how would I do this?
As I have a view with a DN Group called CC Overall and another view with a DN Group called FD, and I need to do a calculation based on the number of calls entered against each of these.
