" /> CCPulse+ Thresholds and Actions (again!) - Genesys CTI User Forum
Author Topic: CCPulse+ Thresholds and Actions (again!)  (Read 4904 times)
tony
« on: March 05, 2007, 12:23:41 PM »
I understand that the options available with CCPulse+ Actions and Thresholds are limited so, before wandering down the road to oblivion yet again, I thought I would ask;
Has anyone attempted to create a Threshold based on Real-Time and an associated Action which exports/appends a View to an external HTML/Excel File?
An example would be;
Based on a [b]Threshold[/b]; at 12:00 (and thereafter every 15 minutes), an [b]Action [/b] is invoked to create an HTML export of a specified View in CCPulse+, which is either a) saved to a external File Location as an HTML File or b) appended to an external, exisiting HTML/Excel File.
I think the way I want to use Thresholds/Actions are self-evident within the example but I wondered if anyone has attempted it and how it might be applied?
Thanks!
Tony
PS: There are reasons why I would not want to create aggregated historical reports via CCA/ICON etc. so please don't suggest those as the standard response!  ;)
« Last Edit: March 05, 2007, 12:28:23 PM by Tony Tillyer »
Marked as best answer by on April 13, 2025, 10:35:35 AM
Offline mark
Re: CCPulse+ Thresholds and Actions (again!)
« Reply #1 on: March 06, 2007, 01:32:46 PM »
  • Undo Best Answer
  • Tony,
    Not sure if it is possible to write an Action to do a whole view export, however you can export individual values to files or a DB. These can then be built into a webpage that can be delivered to users desktops.
    We are doing a soft wallboard project where CCPulse values are exported to a DB then we have created an application that builds the exported data and then passes it onto the agents soft wallboard.
    A very crude version of what you would want, could be an application that takes screen shots of CCPulse at intervals (defined by you) then delivers them to a webserver, which users can link to. Not the nicest thing in the world, but a quick solution!!
    Mark
    tony
    « Reply #2 on: March 06, 2007, 03:40:36 PM »
    Thanks Mark - I'd rather have them use Historical Reporting but for one reason and another it will not fit their needs.
    I suspect I will be looking at this in more detail in the coming weeks, so I'll update this thread as and when things crop up.
    Tony
