Author Topic: Filter After Call Work Lucent G3  (Read 4301 times)
Jim
Lucent G3 and Genesys 5.1
If the softphone is used to request after call work while a call is in progress with attached data, a filter on after call work time against that data will work.
If the physical phone button is used to request after call work while a call is in progress with attached data, the filtered after call work time stat increments even if the filter condition is false.
Has anyone had this issue and found a solution?
