Author Topic: Lost UserData in AgentStarter  (Read 4441 times)
Javier Garagalza
When an event arrives to an agent we can see in the Eventslog component the data attached to the event.
But whe we try to get this data in the Visual Basic code of the AgentStarter application,
the UserData field is not defined, its value is nothing.
Look at the following example:
' Email Handling
Private Sub gdtkEmailExtension_TEvent(EventInfo As DesktopToolkitX.TEventInfo)
On Error GoTo ErrorHandler
Select Case EventInfo.Event
Case EventRinging
Answer gdtkEmailExtension
Case EventEstablished
PopEmail EventInfo.UserData, EventInfo.ThisQueue
End Select
Exit Sub
ErrorHandler:
DisplayErrorMsgBox
End Sub
We are using an Alcatel ACD. We have tried the same code with a Lucent and it works.
