Author Topic: Avaya features ???  (Read 7528 times)
IanDS
Avaya features ???
« on: November 06, 2006, 11:06:17 AM »
I just want to understand what Avaya features people have lost when they have implement Genesys routing. I will give you some examples. Also tell me if you have any of these working using PBX solutions rather than a Genesys solution.
1. Hardphone display will not display VDN name
2. Auto answer tone will slightly change
3. ACW state changes will not be known therefore reporting will be incorrect (not sure if the query timer will see ACW states.( it will see AUX states)
4. VDN / Vector / Skill / Split reports in CMS will be incorrect (if in a multisite environment with no softphone)
5. Ring on no answer (RONA) will not work.
IDS
IanDS
Re: Avaya features ???
« Reply #1 on: November 06, 2006, 11:22:14 AM »
  • actually forget about no#4 that is going to open a can of worms regarding Genesys reporting.....
    Offline mark
    « Reply #2 on: November 06, 2006, 01:54:52 PM »
  • Ian, why do you think #4 will open a can of worms?
    If you need site specific reporting then you can still achieve this within Genesys.
    #6 - loss of whisper on agent transfer
    IanDS
    « Reply #3 on: November 06, 2006, 04:27:06 PM »
  • This customer wants to use as much CMS reports as possible, as they will have a massive change process to convert all the reports to Genesys report + addtional ones that Genesys can provide.
    so fo now it will be a very very small step....
    I didnt design the solution, im just the 'consultat' that is helping the business cope with it all.
    IDS
    Offline mark
    « Reply #4 on: November 06, 2006, 05:15:47 PM »
  • Ahh i see.
    Yes, it could cause a lot of work to be done in building / converting reports. Good money in it for the contractor / vendor that does the work though :D
    Offline ecki
    « Reply #5 on: November 07, 2006, 01:17:31 AM »
  • Hi Ian,
    What exactly does not work on RONA? #5
    Thanks.
    IanDS
    « Reply #6 on: November 07, 2006, 07:39:52 AM »
  • The whole feature does not work.
    If Genesys is delivering a call to an agent directly then the call doenst go throught the PBX ACD, so the feature wont work.
    Ive had route-thru-queue turned on and still doesnt work ( although havent tried it in a long while).
    I would say that if you have a similar functionality working then you might have something programmed in the softphone to requeue the call and make the agent not ready.
    IDS
    Offline ecki
    « Reply #7 on: November 08, 2006, 01:59:46 PM »
  • Thanks mate.
    Macca
    « Reply #8 on: March 28, 2007, 06:16:02 AM »
  • I don't know your set-up but here a way that should allow you to make productive Avaya RONA functionality even when routing directly to agents :
    1. As far as I know each Avaya login requires at least one Avaya Skill / Hunt Group to
    be assigned to it. As a result every agent should have a skill assigned to them.
    2. Set the RONA on this Avaya Skill / Hunt group to deliver calls to a local Route Point.
    3. A strategy can be loaded on this Route Point that can control the routing of bounced  calls.  You could route back to the same skill, use GetConfigOption(StartFromVDN) to pull configurable options to use in the strategy etc.
    I might be missing the point as admittedly this isn't pure Avaya routing but it does allow control of bounced calls. :)
    Cheers.
