" /> Esxi 6.5 and windows 2008 R2 Genesys support - Genesys CTI User Forum
Author Topic: Esxi 6.5 and windows 2008 R2 Genesys support  (Read 561 times)
Offline Leonxxx86
« on: September 12, 2024, 05:00:44 AM »
HI,
Just a question, I believe Genesys 8.1 does not support esxi 6.7 and windows 2008 R2?
My question is, what type of issues might occur under this environment configuration? Thank you
Re: Esxi 6.5 and windows 2008 R2 Genesys support
« Reply #1 on: September 15, 2024, 01:06:23 AM »
As we don't usually test non supported environments... There is no clear answer to this.
Enviado de meu SM-S918B usando o Tapatalk
Offline Leonxxx86
« Reply #2 on: September 18, 2024, 11:28:54 PM »
Thank you, Cav
« Reply #3 on: September 19, 2024, 06:43:23 AM »
What I can tell you is that I remember a customer insisted to install in HyperV version not supported. What happened then is that MCPs began to kinda halt on some calls. Slow audio and weird stuff. We associated it on how the threads were handled. We switched to supported version and began to work without issues.
So... Just can say be ready for anything.
