Author Topic: "No task assigned" when logging in WDE  (Read 470 times)
Offline Gef Buneri
  • Madness is just a point of view.
« on: June 13, 2024, 10:18:36 AM »
When a test agent is trying to log in WDE, it gives this error.
How can I address a solution?
Best,
Gef
Re: "No task assigned" when logging in WDE
« Reply #1 on: June 13, 2024, 11:11:09 AM »
Check user's permissions and assigned roles
Offline Gef Buneri
« Reply #2 on: June 13, 2024, 11:19:41 AM »
Hello Kubig, checked those, everything's seems fine. I have a far memory about something assigned via GAX, can it be? like voice task or something.
« Last Edit: June 13, 2024, 11:32:53 AM by Gef Buneri »
Offline hsujdik
« Reply #3 on: June 13, 2024, 12:04:54 PM »
I remember something like missing execution permission on WDE or SIP Server application. Did you check those?
Offline Gef Buneri
« Reply #4 on: June 13, 2024, 12:08:03 PM »
Yes. Everything points to some rules issue; found a workaround disabling RBAC in the WDE application, but can't find where this "workspace tasks" are to be set in GAX. Can't find a session to do so, nor anything in documentation.
The security documentation says "if this option is set to false (false is the default option), the list of agent tasks must be defined in Genesys Administrator."
« Reply #5 on: June 13, 2024, 12:12:09 PM »
You have to import templates for WDE including the metadata file (XML) which defines the available roles for WDE. I would suggest to use GA instead of GAX to achieve it
Offline Gef Buneri
« Reply #6 on: June 13, 2024, 12:23:23 PM »
Thank you, I'll give a try using Administrator.
