Author Topic: Callback GMS behavior  (Read 595 times)
Offline mahmoud.islam
« on: March 19, 2024, 02:27:56 PM »
I have a strange behavior regarding assigning voice calls to the agents.
Some agents are not connected to any calls for a certain duration even when there is a rush of calls on the queue, and this behavior takes place randomly among all agents.
As an initial analysis, this behavior might be justified as those agents have received call-back requests so they were reserved till the callback interaction took its turn on the queue only then they will be connected to that outbound call.
[b]Is this correct or an expected behavior from the GMS callback service or I should suspect another thing?
[/b]
As I looked into GMS Callback documentation and I did not find a description of how the callback interaction takes place in the queue and its affect to agent handling
Marked as best answer by mahmoud.islam on March 25, 2024, 12:48:58 AM
Re: Callback GMS behavior
« Reply #1 on: March 21, 2024, 12:50:20 PM »
It depends on used callback scenario, callback configuration and at least on routing scripts - I would recommend you to check URS logs to find real root-cause of the issue.
« Reply #2 on: March 24, 2024, 11:48:40 AM »
Indeed, I checked the callback scenarios and I found that the deployed one on my environment is "Classic IVR Callback" and this is a normal behavior.
Much appreciate your insights
