Author Topic: Prefix replacement misbehaviour on Trunk (SipServer 8.1.1)  (Read 537 times)
Offline Gef Buneri
  • Madness is just a point of view.
« on: February 21, 2024, 10:09:07 AM »
Hi all, hope everything's fine out there.
I'm facing a weird behaviour using prefix conversion configured at DN level (trunk). If I set prefix to 88 e.g. and replace-prefix to null, if the dialed numer is 888000, it replaces 3 digits instead of only the initial two.
-- Dialed number was 888000, will replace prefix '888' with ''
But the prefix option is set to 88 Any clue?
**EDIT** just FYI, if I use another prefix like 77 or 87, and the dialed is 778000/878000, it works: Dialed number was 778000, will replace prefix '77' with '', Dialed number was 878000, will replace prefix '87' with ''
Best,
Gef
« Last Edit: February 21, 2024, 11:03:56 AM by Gef Buneri »
Re: Prefix replacement misbehaviour on Trunk (SipServer 8.1.1)
« Reply #1 on: March 02, 2024, 06:50:15 PM »
You can't set to null... Always has to be a valid string
Maybe dial plan is what you need
Enviado de meu SM-S918B usando o Tapatalk
