" /> InteractionEmailSend chain of command. Nothing Happens After Send button click - Genesys CTI User Forum
Author Topic: InteractionEmailSend chain of command. Nothing Happens After Send button click  (Read 3526 times)
Offline Rajnish@49
Hello Everyone,
I am trying to Update a Backend System, After Agent send out email from WDE. I am using Custom Chain of Command InteractionEmailSend. I tried returning true and False both from custom command class. But in none of the case EMail is Sent out. When i hit send button, WDE remains in same Send Screen. In WDE Logs i can see command gets executed and completed.
22-12-31 21:33:12.193 [            32] DEBUG cture.ChainOfCommand - Start Execution of Chain of Command InteractionEmailSend CommandParameter
22-12-31 21:33:12.194 [            32] DEBUG cture.ChainOfCommand - Execute of Chain of Command InteractionEmailSend -> Name:After Send Email Type:Genesyslab.Desktop.Modules.InteractionExtensionSample.AfterSendEmail
22-12-31 21:33:12.206 [            32] DEBUG cture.ChainOfCommand - Stop of Execution of Chain of Command 'InteractionEmailSend' by command 'After Send Email'
22-12-31 21:33:12.208 [            32] INFO  cture.ChainOfCommand - End of Execution of Chain of Command InteractionEmailSend (  14.912 ms)
Please find below the code of CUstomcommand CLass and COmmand Activator.
            commandManager.InsertCommandToChainOfCommandAfter("InteractionEmailSend", "Send",
                new List<CommandActivator>() { new CommandActivator() {
                CommandType = typeof(SendEmail), Name = "CaseReleaseCustomCommand"
Custom Command:-
    class SendEmail: IElementOfCommand
        readonly IObjectContainer container;
        ILogger log;
        IInteractionManager interactionManager;
        public INotepadViewModel notepadViewModel { get; }
        public SendEmail(IObjectContainer container, IInteractionManager interactionManager, INotepadViewModel notepadViewModel)
            this.container = container;
            this.interactionManager = interactionManager;
            this.notepadViewModel = notepadViewModel;
            // Initialize the trace system
            this.log = container.Resolve<ILogger>();
            // Create a child trace section
            this.log = log.CreateChildLogger("WDE Cust Debug:-- Send Email button clicked");
        public string Name { get { return "Before Send Email"; } set { } }
        public object Context { get; set; }
        public bool Execute(IDictionary<string, object> parameters, IProgressUpdater progress)
            // To go to the main thread
            if (Application.Current.Dispatcher != null && !Application.Current.Dispatcher.CheckAccess())
                object result = Application.Current.Dispatcher.Invoke(System.Windows.Threading.DispatcherPriority.Send, new ExecuteDelegate(Execute), parameters, progress);
                return (bool)result;
            else
                // Ok, we are in the main thread
                return true;
        /// <summary>
        /// This delegate allows to go to the main thread.
        /// </summary>
        delegate bool ExecuteDelegate(IDictionary<string, object> parameters, IProgressUpdater progressUpdater);
Please Help!!
Rajnish
Marked as best answer by Rajnish@49 on January 03, 2023, 09:34:40 AM
Offline hsujdik
Hello. Here are some thoughs that could help you.
On this:
[quote]
I would replace with just:
[code]
public string Name { get ; set ; }
[/code]
Since the name is set on the Command Activator and it might be needed to be found in the execution Chain (not sure, though).
Not mandatory, but keep the Child Log name short, since the name is trimmed on the logs for the last few characters:
[quote]
[b]change to something short that you can lookup later, like:[/b]
this.log = log.CreateChildLogger("WDECustDebug");
on the Execute method, insert something on the log just to see if it really firing your custom command:
[quote]
            [b]this.log.Error("Executing my custom SendEmail class");[/b]
and finally, return [b]false[/b] on your Execute method. Returning "true" means you should stop executing the next steps of the chain of command.
If it still doesn't work, try inserting your command at the beginning of the chain of commands, just to see if it runs - maybe another "Default" WDE command is stopping its execution:
[quote]
            commandManager.CommandsByName["InteractionEmailSend"].Insert(0,
