" /> How to uninstall Genesys Red Hat packages - Genesys CTI User Forum
Author Topic: How to uninstall Genesys Red Hat packages  (Read 1513 times)
Offline rocio2020
« on: December 05, 2021, 06:53:25 AM »
Hello dears,
Thank you for this very helpful forum, I have a problem when uninstalling some packages on a Red Hat 8, I want to uninstall the LCA and I can't, I try with the commands: remove, erase but I can't.
Example: yum remove Local Control Agent and it appears that the package is not installed but when I run the: top command I see the process running.
Please I need a scoping about it or a correct procedure.
Re: How to uninstall Genesys Red Hat packages
« Reply #1 on: December 05, 2021, 10:46:18 AM »
Genesys apps prior today are managed as binaries so you cannot managed it via package repo like yum. You can just remove the binaries and probably disable/remove related services from systemctl in case of you're using that.
