" /> Agent's name is garbled in CCPulse. - Genesys CTI User Forum
Author Topic: Agent's name is garbled in CCPulse.  (Read 1450 times)
Offline josh22022
« on: November 19, 2021, 09:14:27 AM »
Hi everyone,
I have no idea how to display agent's name in Chinese. It is garbled in CCPulse now.
CCPulse version : 7.1.000.10
Stat Server version : 8.5.112.23
Thanks all,
Josh
Re: Agent's name is garbled in CCPulse.
« Reply #1 on: November 19, 2021, 01:12:12 PM »
Hi
Could be an encoding issue.
CCPulse has no longer support from Genesys but should work as long as all components are under same encoding.
CfgServer is UTF8?
Offline josh22022
« Reply #2 on: November 22, 2021, 01:55:11 AM »
Yes, the CfgServer option is "encoding = utf-8 "
Offline catanirex
« Reply #3 on: November 22, 2021, 01:22:06 PM »
CfgServer option is "encoding = utf-8 " only means that export using CCW will be in utf-8. It is not saying that data is stored in utf-8
You need to check startuplogs for configserver or check database to see that init_multi_multilang_mssql.sql was run instead of normal init_multi_mssql.sql
