" /> Genesys Configuration Manager is not login to configuration server on windows se - Genesys CTI User Forum
Author Topic: Genesys Configuration Manager is not login to configuration server on windows se  (Read 1137 times)
Offline kalakshmanakumar
Configuration Manager is not supported windows server 2019, i read some article in that they have mentioned  added windows server 2019 into ip_description.xml under Platforms tag  <Computer Type="Intel 32 bit"> and <Computer Type="Intel EM64T"> then installation is gone through. Post installation trying to login CME it is not working (Data Communication Manager - Error Message red X mark and SUCCESS" screenshot attached below.
[img]https://higherlogicdownload.s3.amazonaws.com/GENESYS/MessageImages/910b36f452794aac8b7d86a94662ac52.png[/img]
Genesys Administrator also not working on windows server 2019.
How i can make it work, please advice
CME is already faced out.
You need to use GA/GAX or use CME just on your PC.
