" /> Registering Comm DN from WWE custom app - Genesys CTI User Forum
Author Topic: Registering Comm DN from WWE custom app  (Read 1415 times)
Offline genesys_kumar
« on: November 12, 2021, 10:25:49 PM »
I'm trying to register communication DN from WWE Custom application.  Is there any API available to register DN?
Kumar
Offline hsujdik
Re: Registering Comm DN from WWE custom app
« Reply #1 on: November 13, 2021, 01:20:29 AM »
As far as I am aware, there is not. Is there any specific need for registering to the Communication DN though? I ask, because there are API endpoints for dealing with Outbound resources.
« Reply #2 on: November 15, 2021, 01:10:52 PM »
Registering Comm DN to broadcast messages to agents.  actually we are trying to control custom features enable/disable at live without forcing agents to logout and login back.
Kumar
« Reply #3 on: November 15, 2021, 02:54:39 PM »
I think WWE doesn't support Broadcast feature. Even in WDE you need to develop a custom software to make it work, it is not Out of the Box ready to use.
« Reply #4 on: November 15, 2021, 05:22:41 PM »
In WDE, we have this feature as OOB i've implemented for some customers and i know this feature is not available in WWE, if we have api to register DN we can customize it.
So if anyone knows the API to register DN, that will help me to customize WWE.
Kumar
« Reply #5 on: November 15, 2021, 07:32:20 PM »
WDE can receive the broadcast events, true. However, won't send unless you build something to send the events. So can't be OOB.
WDE doesn't register CommonDN or anyother DN, SIP Server does. What WDE is, request TServer to monitor that DN. WWE doesn't have such. You would need to build an app/plugin for it.
Or build a parallel application.
