Author Topic: TServer cannot start. License error.  (Read 2039 times)
Offline Harifidy
« on: October 12, 2021, 07:57:08 PM »
Hi.
I installed TServer on localhost, but it cannot start.
Log:
Connecting to LCA at port 4999...
Open LCALayer on port=4999
LCA Library version 7.5.000.06
GLM_CO(tserver_sdn:switch_107,20,1)=-99
10:16:41.126 Std 07100 Licensing violation is identified, the violation type GLMR_LICENSE_SERVER_NOT_AVAILABLE
10:16:41.126 Std 05066 Initialization of license failed, reason 'GLMR_LICENSE_SERVER_NOT_AVAILABLE'
10:16:41.126 Std 05062 Application initialization failed, reason 'license error'
10:16:41.126 Trc 04109 Logging service stopped
License manager contains a valid Server/MAC  adress value.
The "re_read license" returns failed.
I really appreciate your help.
Thank you.
Re: TServer cannot start. License error.
« Reply #1 on: October 12, 2021, 09:49:51 PM »
As you can easily see from posted logs, there is a general issue with license file. Check if the license file is valid or consult it with your Genesys representative.
Offline Janis
« Reply #2 on: October 12, 2021, 09:51:35 PM »
What is the exact error of reread?
What you see in FlexLM log file?
Is TServer connecting to right host and port?
« Reply #3 on: October 13, 2021, 01:59:58 PM »
Verify the host name as well.
Using LMTOOLS, if using Windows, check if it is well configured.
Offline Harifidy
« Reply #4 on: October 14, 2021, 05:04:47 AM »
Thank tou for tour help.
LMTOOLS is well configured.
The TServer is connected to right host and port.
I am going to check if the license I am using is a valid one.
Offline hsujdik
« Reply #5 on: October 15, 2021, 10:29:09 PM »
If you perform the 'query server' on the LMTOOLS, do you see a list of available licenses?
I believe you have to place the FQDN on the license file (including the domain part - not only the hostname)
« Reply #6 on: October 15, 2021, 10:59:00 PM »
LMTOOLS will tell you also which values to put into the license file as hostname.
Offline Harifidy
« Reply #7 on: October 18, 2021, 08:00:12 AM »
Hi.
Actually, the License Manager was not running on "service". I started it manually then it worked.
Thank you.
