Author Topic: SpeechMiner: cannot upgrade  (Read 1439 times)
Offline Harifidy
« on: September 29, 2021, 12:55:55 PM »
Hi, I try to Upgrade SpeechMiner (to version 8.5.5)
I follow this document [url=https://enu.docs.genesys.com/Documentation/SPMI/8.5.5/Upgrade/anyto85510]https://enu.docs.genesys.com/Documentation/SPMI/8.5.5/Upgrade/anyto85510[/url] to do that.
(I followed the requirement and the procedure.)
But when I run (As Admin) SMUprade.exe, After I answered the first question " you are sure you want to continue" by yes
I get an error on my log:
[code]
Error: An error occured before the DB was changed: Failed to initialize DB Master.
SMUpgrade.UpgradeFailedException: Failed to initialize DB Master. ----> System.Exception: Could not connect to the DB
[/code]
My userId is already "sa"
Could anyone help me please.
Thank you  :)
Re: SpeechMiner: cannot upgrade
« Reply #1 on: September 29, 2021, 01:13:31 PM »
There are some DB scripts Genesys must provide.
SM is always tricky. Open an eSR tell them from which to what version you are upgrading, if using ES or Lucene and then they will tell you the proper steps and scripts.
SA doesn't guarantee connection tho, open an ODBC panel and try connection from there
Offline Harifidy
« Reply #2 on: September 29, 2021, 03:09:12 PM »
Thank you for your reply.
Before I  do anything, I forgot to mention that the machine where there is the SM and the one where there is the database are two different servers.
So are there other config that I need to check in such a situation.
Thank you.
« Reply #3 on: September 29, 2021, 07:41:48 PM »
Try the ODBC test first.
The error you may be getting is also possible if DB was not upgraded yet, for which you may need some scripts.
Which is your current version?
Are you using already ES?
Offline Harifidy
« Reply #4 on: September 30, 2021, 10:45:05 PM »
I tried to do the ODBC test but I failed, so I decided to abandon the Upgrade to 8.5.512 but install the current version 8.5.509
There was no error on configuration, but when I try to launch the web http://localhost/speechminer, I get a "Runtime Error"
[url=https://ibb.co/1RG4t8W][img]https://i.ibb.co/1RG4t8W/Capture.png[/img][/url]
Is there something I was missing on web.config or on configuration?
Thank you
« Reply #5 on: October 01, 2021, 02:59:03 PM »
Hard to tell without logs or knowing what you did, but I would re-configure my WAS in SMConfig.
