Author Topic: Genesys call recording with nice, also save to local file on mcp  (Read 1599 times)
Offline msh
« on: September 16, 2021, 11:40:06 AM »
Hi
We are having a Genesys engage on-remember solution where we have call recording with nice.
For a small project we would also like to have call recordings created as local files on the MCP.
Looking at the documentation it seems the the option recordingclient.recdest2 (on the recording profile) would allow us to do a second recording as a file but setting it to file://d:\mcp\record (for example) seems to have no effect, and nothing logged in the logs.
Does anyone know if this is the way forward or is there some other way to do local file recordings in parallel to nice?
Re: Genesys call recording with nice, also save to local file on mcp
« Reply #1 on: September 16, 2021, 01:59:33 PM »
You are using MCP to send the RTP directly to Nice. MCP no longer stores it as a WAV file.
You can't have both.
Offline msh
« Reply #2 on: September 16, 2021, 05:41:01 PM »
Thanks, that's too bad. Do you know of any other way to achieve this?
« Reply #3 on: September 16, 2021, 08:41:36 PM »
You could sniff the RTP in the network and capture the audios there.
Some recorders work on this way
« Reply #4 on: September 20, 2021, 12:36:22 PM »
[color=#444a52][font=roboto, arial, sans-serif][size=15px]When recdest / recdest2 are both configured, they must be both sip / sips, [b]OR [/b]both one of the other possible destinations. Additional notes related to sip / sips destination: When recdest is set to RM (SIP AOR), MCP will use this in the Request-URI address part of the recording server request.[/size][/font][/color]
« Last Edit: September 20, 2021, 12:40:06 PM by cavagnaro »
Offline Fra
« Reply #5 on: October 14, 2021, 03:42:54 PM »
[quote author=cavagnaro link=topic=12128.msg54353#msg54353 date=1631800773]
Not necessarily, it depends on the integration.
