Author Topic: CCPulse+ ObjectFormat configuration  (Read 1406 times)
Offline rolf_b
« on: September 13, 2021, 02:47:08 PM »
I am trying to adapt the display format for agents. Currently, we use FormatAgentInfo in the registry; I need to get rid of this. Instead, I want to use ObjectFormat / Agent in the CCPulse application object.
But:
- the documentation is totally unsatisfying. I know what C format strings are, but in in what order does ccpulse pass the values? That's not described
- CCPulse doesn't accept any entry. Even the example "%.5s, %.5s %.5s" from the manual is rejected as invalid.
CCPulse supposedly supports ObjectFormat since version 8.0.1.
I am running CCPulse+ 8.1.100.68. In my application object, I created an ObjectFormat section and an Agent entry. Since I am receiving an error, this is the place where CCPulse is looking, but it's not happy with my entries.
What am I missing?
Greetings
Rolf
« Last Edit: September 13, 2021, 02:54:19 PM by rolf_b »
Re: CCPulse+ ObjectFormat configuration
« Reply #1 on: September 13, 2021, 03:04:11 PM »
From Genesys KB
000085172
Article Type Q&A
Title How to configure CCPulse options in ObjectFormat section
Summary
Question/ Problem
How to configure CCPulse options in ObjectFormat section.
From Reporting 8.1 CCPulse+ Administrator’s Guide (Document Version: 81rt_ad_ccpulse+_11-2014_v8.1.001.00)
Example: Formatting an Agent
For EmployeeID=Employee, FirstName=Johnathon, and LastName=Smith
• %.5s, %.5s %.5s
produces the following result:
Emplo, John Smith
• %.6s, %.7s %.5s
Employ, Johnath Smith
The examples do not clearly show how to setup CCPulse options in ObjectFormat section.
Answer/ Details
Example of CCPulse options for ObjectFormat section:
Agent=%.5s, %.4s %.5s; EmployeeID, FirstName, LastName
Emplo, John Smith
Agent=%.6s, %.7s %.5s; EmployeeID, FirstName, LastName
Examples for ObjectFormat section :
1. %d %s %d; DBID, Tenant, TenantDBID
Applicable for all objects, including Agents and DNs
2. %s; name
Applicable for all objects, except Agents
3. %s - %s.%s; EmployeeID, FirstName, LastName
Applicable only for Agents.
4. %s, %s, %s; Alias, SwitchName, Number
Applicable only for the following objects(DNs):
-DN
-ACDPosition
-Chat
-CoBrowse
-Dialer
-Email
-Extension
-ExternalRoutingPoint
-ExternalRoutingPointInTheGroup
-Fax
-Queue
-QueueInTheGroup
-RoutePoint
-RoutePointInTheGroup
-RoutingQueue
-RoutingQueueInTheGroup
-ServiceNumber
-ServiceNumberInTheGroup
-Video
-VirtualQueue
-VirtualQueueInTheGroup
-VirtualRoutePoint
-VirtualRoutePointInTheGroup
-VoiceTreatmentPort
-VoIP
Supplemental Information
For more information about object format settings and printf function, refer to http://www.cplusplus.com/reference/clibrary/cstdio/printf/.
Offline rolf_b
« Reply #2 on: September 13, 2021, 04:02:09 PM »
Hello cavagmaro,
after some initial confusion, I finally saw what I was missing: the configuration entry consists of two parts, separated by a semicolon:
(1) The format string
(2) The list of properties to format
Yes, the manual states that. And I read that. But the following examples just show the format part, not the property list. And stupid me forgot what I had read.
Using [font=courier]"%s %s %s; EmployeeId, FirstName, LastName"[/font] as a ObjectFormat value for Agent works. I can build on that.
Thank you very much
Rolf
« Reply #3 on: September 14, 2021, 01:46:11 AM »
;D ;D  Great it helped
Yeah, Genesys docs can be confusing even after reading 3/4 times. Have been there too.
