Author Topic: restricted access to workbind  (Read 2485 times)
Offline mguzman
« on: April 16, 2021, 05:14:25 PM »
Hello everybody
I would like to know how to do so that only a particular agent group can see some workbinds
Re: restricted access to workbind
« Reply #1 on: April 17, 2021, 03:33:28 AM »
Assign them only to their WDE app options, you will need to create separate ones for each need you require
Offline mguzman
« Reply #2 on: April 20, 2021, 12:43:21 PM »
Could you tell me what is the option that I would have to add in the application?
I looked in the manuals but did not find something that works for me
« Reply #3 on: April 20, 2021, 07:56:50 PM »
The Workbin options, where you enable which Workbin is availble.
https://docs.genesys.com/Documentation/IW/latest/Dep/WorkbinOptions
