" /> strattribute1-10 - Genesys CTI User Forum
Author Topic: strattribute1-10  (Read 2444 times)
Offline Ardim
strattribute1-10
« on: April 10, 2021, 05:55:59 PM »
I'd like to search interactions  in UCS for contactId and any (user defined strattributeNN).
The code looks something like this:
        SearchCriteriaCollection scStartAt = SearchCriteriaBuilder.Build(InteractionSearchCriteriaConstants.StartDate,
        Operators.Greater,
        SomeDate);
        RequestGetInteractionsForContact requestGetInteractionsForContact = new RequestGetInteractionsForContact
          ContactId = contact_id,
          EntityTypeId = EntityTypes.Chat,
          SearchCriteria = scStartAt,
          SortCriteria = sortCriteria
But if I add to search any attributes predicate I see error or the same as without attributes predicate result. Did anyone have similar problems and how did they solve them ?
Marked as best answer by Ardim on April 14, 2021, 06:25:51 PM
Offline gen_rtfm
Re: strattribute1-10
« Reply #1 on: April 12, 2021, 09:16:12 PM »
Are the strattributeNN-fields indexed in ucs?
Do you have any examples of errors to share?
Also: do you have same behavior when performing a search (with same search criteria) from a standard genesys application like WDE? if not, the logs from that application are pretty verbose in how it constructs it's request to ucs.
I haven't had any experience with this myself but that's where I'd look.
Br
Skickat från min Mi MIX 3 5G via Tapatalk
Offline Ardim
« Reply #2 on: April 14, 2021, 05:25:09 AM »
Precisely! And how I didn't think of it right away. Reindexed the entire database forcibly and the problem disappeared. Thank you !  :)
