Author Topic: Custom ors-service hosted on gms  (Read 3703 times)
Offline gen_rtfm
« on: November 24, 2020, 11:02:18 AM »
Hi!
I was wondering if anybody has made a custom ors-service for gms?
Looking at the callback-services they are all executed (mostly) on ors... Figured it might be a nice thing to try to keep custom apis made for genesys available via gms, instead of a separate hosting?
If anybody has a composer skeleton for developing such a service I'd be thrilled if that could be shared [emoji6]
Skickat från min Mi MIX 3 5G via Tapatalk
Re: Custom ors-service hosted on gms
« Reply #1 on: November 24, 2020, 04:03:52 PM »
I've developed similiar scenario using Interaction Less routing by ORS
Offline gen_rtfm
« Reply #2 on: November 24, 2020, 04:13:15 PM »
[quote author=Kubig link=topic=11912.msg53606#msg53606 date=1606233832]
[/quote]Nice!
Do you have any advice to share?
Offline gen_rtfm
« Reply #3 on: November 27, 2020, 04:30:23 PM »
[quote author=gen_rtfm link=topic=11912.msg53607#msg53607 date=1606234395]
[/quote]Nice!
[/quote]Ok, so i managed to figure the "major parts" and have a custom service accessible via gms. Did you manage to pass parameters from the request to the workflow Kubig? I can't seem to figure out how that's done...
Offline gen_rtfm
« Reply #4 on: November 30, 2020, 04:58:36 PM »
Today's update:
I was able to get parameters passed by including them in the scxml project properties, then creating a dfm for my custom service based off the callback-dfm, and then pointing to that in ors config.
A few quirks to iron out and i'm not sure it's a good fit for me, seems like an awful lot of overhead for small apis.
But I'm glad I got it working to some extent ;)
« Reply #5 on: November 30, 2020, 05:10:42 PM »
Any input parameter starting with underscore character is automatically passed to your workflow. You can get its then by using "_data.<your parameter name incl. underscore character>" expressions.
« Reply #6 on: November 30, 2020, 05:13:46 PM »
Hi again,
Please check Technical Tutorial #116 on Genesys Care website for interaction-less processing details incl. sample.
Offline gen_rtfm
« Reply #7 on: November 30, 2020, 05:26:15 PM »
[quote author=René link=topic=11912.msg53611#msg53611 date=1606756426]
Hi again,
[/quote]Thanks for the tip, I'll check it out!
