Author Topic: Extracting StatServer EventInfo data  (Read 2397 times)
Offline oceanblue
« on: November 11, 2020, 08:38:17 PM »
To all PSDK gurus :
I wrote a small Java PSDK(StatServer) script which prints EventInfo event generated by the StatServer reflecting Agent Place/DB info. Following is a sample output :
'EventInfo' (2) attributes:
        VOID_VALUE [object] = ObjectValue: AgentStatus {
  AgentId = 07008
  LoginId = 07008
  Status = 8
  Time = 1605122633
  Place = PlaceStatus {
    PlaceId = Test_Agent_Place
    PlaceStatus = 8
    Time = 1605122633
    DnStatuses = DnStatusesCollection (size=1) [
      [0] DnStatus {
        DN Id = 9100057
        SwitchId = SIPSwitch1
        GSW DN TYPES = 1
        DN Status = 8
        Time = 1605122633
        Actions = DnActionCollection (size=1) [
          [0] DnAction {
            Action = NotReadyForNextCall
            Time = 1605122633
            ActionDataType = CallData
            ConnectionId = 0000000000000000
            DNIS = null
            ANI = null
            UserData = KVList:
'ReasonCode' [str] = "Login"
'INTERACTION_WORKSPACE' [str] = "8.5.126.7"
        TM_LENGTH [int] = 0
        LONG_VALUE [int] = 0
        USER_REQ_ID [int] = -1
        TM_SERVER [int] = 1605124112
        REQ_ID [int] = 53829
My Challenge is that I couldn't find a way to extract various [b]PlaceStatus[/b] and [b]DNStatus[/b] info from the above output. I tried different permutations of casting the EventInfo/message to PlaceStatus/DnStatus objects without any success.
Could someone tell me how it can be done leveraging the current StatServer API methods?
Thank you so much for reading this and I will appreciate your input into it.
cheers,
Offline PeteHoyle
Re: Extracting StatServer EventInfo data
« Reply #1 on: November 13, 2020, 04:20:12 PM »
You first need to cast it to an AgentStatus, then from there you can get the PlaceStatus and from there the DN Status
I don't have an easy to ready Java example at the moment, but here is a C# example:
[code]
        private void OnEventInfo(IMessage theMessage)
            EventInfo statisticsInfo = theMessage as EventInfo;
            if (statisticsInfo != null)
                if (statisticsInfo.StateValue is AgentStatus)
                    AgentStatus status = (AgentStatus)statisticsInfo.StateValue;
                    PlaceStatus place_status = status.Place;
                    string myStatus = place_status.Status.ToString();
                    DnCollection dn_coll = place_status.DnStatuses;
                    foreach (DnStatus dn_status in dn_coll)
                        Console.WriteLine("DN IS : " + dn_status.DnId);
                Console.WriteLine("EventInfo:\n" + statisticsInfo + "");
                writeLog(statisticsInfo.ToString());
[/code]
It should be easy enough to convert to Java, if you have problems let me know..
Pete
