Author Topic: ERROR [BotsManager] - ChatBotFactory service not found in jar  (Read 4368 times)
Offline Rajnish@49
Hello All,
I am creating a ChatBot using NetBeans 11.1. I am getting this error in DMS while loading of Bot.
ERROR [BotsManager] - ChatBotFactory service not found in jar  AmazonLexRestAccess_V1-1-jar-with-dependencies.jar
ERROR [BotsManager] - Failed to load bot plugin from: AmazonLexRestAccess_V1-1-jar-with-dependencies.jar
Below is the code:-
AmazonLexRestAccess_V1.java
public class AmazonLexRestAccess_V1 implements ChatBot {
    private ChatBotPlatform cbpInstance;
    private Logger logger; // bot-session aware logger
    private GenesysChatSession session;
    @Override
    public void setCbpInstance(ChatBotPlatform cbpInstance) {
        this.cbpInstance = cbpInstance;
        this.logger = cbpInstance.getLogger();
    @Override
    public void onCommandStart(GenesysChatSession session, int eventJoinedId, EspRequestParameters espParameters) {
        // TODO to be implemented
        this.session = session;
        cbpInstance.sendMessage("Thank you for contact Thermo Fisher scientific!! How may i help you today?");
    @Override
    public void onCommandStop(StopReason reason, ChatEventInfo eventInfo, EspRequestParameters espParameters) {
    @Override
    public void onSessionActivity(ChatEventInfo eventInfo) {
                ChatUserInfo originator = session.getParticipant(eventInfo.getUserId());
        if (eventInfo.getEventType() == EventType.MESSAGE && originator.getUserType() != UserType.SYSTEM && originator.getUserType() != UserType.EXTERNAL)
            if (eventInfo.getMessageText().matches("stop(:(keep_alive|force_close|close_if_no_agents))?"))
                Action action = Action.KEEP_ALIVE;
                String[] tokens = eventInfo.getMessageText().split(":");
                if (tokens.length > 1)
                    action = Action.valueOf(tokens[1].toUpperCase());
                // The bot decides to stop execution.
                // The bot will be removed from chat session and discarded in BGS.
                // If running in waiting mode, the interaction will be released in workflow.
                // If the bot need to communicate something to workflow, it could invoke updateUserdata at this moment.
                logger.info("Leaving chat session with after-action: " + action.name());
                cbpInstance.leaveSession(action);
            else
              logger.info("Message Typed"+eventInfo.getMessageText());
                cbpInstance.sendMessage(eventInfo.getMessageText());
                AWSCredentials awsCreds=new BasicAWSCredentials("AccessKey","SecretKey");
                //AmazonLexModelBuilding buildClient=AmazonLexModelBuildingClientBuilder
                AmazonLexRuntime client= AmazonLexRuntimeClientBuilder.standard().withRegion(Regions.US_EAST_1).withCredentials(new AWSStaticCredentialsProvider(awsCreds)).build();
                cbpInstance.sendMessage("Creds sent");
                PostTextRequest postRequest=new PostTextRequest();
                postRequest.setBotAlias("BookATrip_VFirst");
                postRequest.setBotName("BookATrip_VFirst");
                postRequest.setUserId("BotAccessRestAPI");
                postRequest.setInputText(eventInfo.getMessageText());
                cbpInstance.sendMessage("RequestMessage sent");
                logger.info("Message Executed Till Build PostRequest");
                PostTextResult textResult=client.postText(postRequest);
                cbpInstance.sendMessage(textResult.getMessage());
                logger.info("Echoing back message: " + eventInfo.getMessageText());
    @Override
    public void onCommandUpdate(EspRequestParameters espParameters) {
AmazonLexRestAccess_V1Factory
public class AmazonLexRestAccess_V1Factory implements ChatBotFactory {
    private static final Logger LOG = LoggerFactory.getLogger(AmazonLexRestAccess_V1Factory.class);
    public void initialize(KeyValueMap configuration) {
    public void configurationUpdated(KeyValueMap configuration) {
    public void shutdown() {
    public ChatBot createChatBot(KeyValueMap espParameters, ChatInteractionInfo interactionInfo, BotCreationAttributes botCreationAttributes) {
        return new AmazonLexRestAccess_V1();
    @Override
    public String getBotId() {
        return "AmazonLexRestAccess_V1";
« Last Edit: June 16, 2020, 11:36:47 AM by Rajnish@49 »
Re: ERROR [BotsManager] - ChatBotFactory service not found in jar
« Reply #1 on: June 16, 2020, 03:35:57 PM »
Did you add all your referenced libraries?
Offline Rajnish@49
« Reply #2 on: June 16, 2020, 03:42:20 PM »
Thanks Kubig...
I am very new to netBeans. so apologies...
While i Clean & Build. Only one Jar file is getting generated. And place the same in bots-repo.
Could you please help where  would need to add those libraries?
I have added reference in my code and pom.xml as well.
import com.amazonaws.auth.AWSCredentials;
import com.amazonaws.auth.AWSStaticCredentialsProvider;
import com.amazonaws.auth.BasicAWSCredentials;
import com.amazonaws.regions.Regions;
import com.amazonaws.services.lexruntime.AmazonLexRuntime;
import com.amazonaws.services.lexruntime.AmazonLexRuntimeClientBuilder;
import com.amazonaws.services.lexruntime.model.PostTextRequest;
import com.amazonaws.services.lexruntime.model.PostTextResult;
        <dependency>
            <groupId>com.amazonaws</groupId>
            <artifactId>aws-java-sdk-core</artifactId>
            <version>1.11.96</version>
            <type>jar</type>
        </dependency>
        <dependency>
            <artifactId>aws-java-sdk-lex</artifactId>
            <type>jar</type>
        </dependency>
« Reply #3 on: June 16, 2020, 04:13:46 PM »
[quote]If your bot needs to use 3rd party libraries, you have the option to use maven-assembly-plugin and these libraries will be included into the resulting JAR file.[/quote]
Offline Rajnish@49
« Reply #4 on: June 16, 2020, 07:33:02 PM »
I am using maven-assembly-plugin to generate one jar file with all dependencies. DMS>>BGS throws error
2020-06-16T19:29:04,324 Std 45302 (CBP.platform) ERROR [BotsManager] - ChatBotFactory service not found in jar: LexV2-1.0-SNAPSHOT-jar-with-dependencies.jar
2020-06-16T19:29:04,324 Std 45302 (CBP.platform) ERROR [BotsManager] - Failed to load bot plugin from: LexV2-1.0-SNAPSHOT-jar-with-dependencies.jar
« Reply #5 on: June 16, 2020, 08:03:53 PM »
Check the references at NetBeans. You must add that jar into the lib
Offline Rajnish@49
« Reply #6 on: June 29, 2020, 08:24:10 PM »
Finally I was able to figure out the problem with Help of Genesys. We would need to generate Jar files as build with dependencies  and using below build properties in pom.xml and used ChatBot API of DMS version=9.1.003.12
    <build>
    <plugins>
      <plugin>
        <artifactId>maven-assembly-plugin</artifactId>
        <version>2.3</version>
        <executions>
          <execution>
            <phase>package</phase>
            <goals>
              <goal>single</goal>
            </goals>
          </execution>
        </executions>
        <configuration>
          <descriptors>
            <descriptor>jar-with-deps-with-exclude.xml</descriptor>
          </descriptors>
        </configuration>
      </plugin>
      <plugin>
        <groupId>org.apache.maven.plugins</groupId>
        <artifactId>maven-compiler-plugin</artifactId>
        <version>2.3.2</version>
        <configuration>
          <encoding>UTF-8</encoding>
        </configuration>
      </plugin>
      <plugin>
        <artifactId>maven-resources-plugin</artifactId>
        <version>2.4.3</version>
        <configuration>
        </configuration>
      </plugin>
      <plugin>
        <artifactId>maven-jar-plugin</artifactId>
        <version>3.0.2</version>
        <configuration>
          <archive>
            <manifest>
              <addDefaultImplementationEntries>false</addDefaultImplementationEntries>
            </manifest>
          </archive>
        </configuration>
      </plugin>
    </plugins>
  </build>
In project Directory I am using file=jar-with-deps-with-exclude.xml
<?xml version="1.0" encoding="UTF-8"?>
<assembly xmlns="http://maven.apache.org/ASSEMBLY/2.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/ASSEMBLY/2.0.0 http://maven.apache.org/xsd/assembly-2.0.0.xsd">
  <id>exclude-classes</id>
  <formats>
    <format>jar</format>
  </formats>
  <includeBaseDirectory>false</includeBaseDirectory>
  <dependencySets>
    <dependencySet>
      <outputDirectory>/</outputDirectory>
      <useProjectArtifact>false</useProjectArtifact>
      <unpack>true</unpack>
      <scope>runtime</scope>
      <excludes>
        <exclude>org.slf4j:slf4j-api</exclude>
      </excludes>
    </dependencySet>
  </dependencySets>
  <fileSets>
    <fileSet>
      <directory>${project.build.outputDirectory}</directory>
    </fileSet>
  </fileSets>
</assembly>
