Author Topic: Genesys IVR Automate Testing  (Read 5637 times)
Offline vijayp_genesys
« on: February 05, 2020, 09:16:48 PM »
I have self service IVR and is there a way i can write scripts to automate my IVR testing
Offline hsujdik
Re: Genesys IVR Automate Testing
« Reply #1 on: February 06, 2020, 01:02:27 PM »
We have used this one in the past: https://cyara.com/solutions/ivr-testing/
A little bit difficult to set up but works fine
« Reply #2 on: February 06, 2020, 03:35:27 PM »
I heard about cyara and is good but feel licensing cost is high. As a first step, i want to automate testing on IVR callflow
« Reply #3 on: February 06, 2020, 04:56:30 PM »
Well... That is not a simple task as many possibilities and result evaluations are the most important part exactly.
So, there are not many options actually.
« Reply #4 on: February 09, 2020, 07:28:45 PM »
There is the Genesys Workbench 9.0 that is just released. It has some automation tools for IVR, maybe can help you on what you need
Offline hsujdik
« Reply #5 on: February 10, 2020, 10:07:23 AM »
[quote author=cavagnaro link=topic=11533.msg52501#msg52501 date=1581276525]
Nice! I'll give it a try too
« Reply #6 on: February 14, 2020, 02:46:24 PM »
Thank You, I will definitely try and post back the result
Offline genesysguru
    • Genesys Guru Blog
« Reply #7 on: February 16, 2020, 05:48:44 PM »
Re: Workbench 9 - Yes, only take them 3 years to catch up with me!
http://genesysguru.com/blog/blog/2017/06/14/genesys-integration-on-the-wire-iotw/
https://docs.genesys.com/Documentation/ST/latest/WorkbenchUG/WorkbenchDiscoverConsole
Regards
