Author Topic: WDE Default Agent Status  (Read 3232 times)
Offline Dafne88
« on: November 28, 2019, 07:11:24 AM »
I wanted to know if it is possible to configure a default agent state when logging on the WDE, the default status should be a custom not ready.
Thank you very much  ;D
p.s. this is my first post sorry if I did something wrong  :-[
Offline PeteHoyle
Re: WDE Default Agent Status
« Reply #1 on: November 28, 2019, 10:27:42 AM »
Have a look at the options 'login.<MediaName>.auto-not-ready-reason'
For example 'login.voice.auto-not-ready-reason'
https://docs.genesys.com/Documentation/Options/Current/IW/WDE-interaction-workspace#login-voice-auto-not-ready-reason
Offline Dafne88
« Reply #2 on: November 28, 2019, 11:07:54 AM »
thank you so much, I try to configure as indicated in the link! ;)
