Author Topic: SpeechMiner wild card search  (Read 1947 times)
Offline genesysnoob
« on: October 09, 2019, 06:45:17 PM »
Doesn't work.
As suggested by genesy i updated muxer.cfg file
call_recording_query_string =callerPhoneNumber and it still doesn't work
I did searches using  *Number, *number*
Re: SpeechMiner wild card search
« Reply #1 on: October 10, 2019, 10:52:06 AM »
What is the issue or what do you want to achieve? Mixer has nothing to do with searching itself.
Offline genesysnoob
« Reply #2 on: October 10, 2019, 06:41:22 PM »
[quote author=Kubig link=topic=11456.msg52206#msg52206 date=1570704726]
In speech miner under the metadata section, if we select ani, can we do wild card search?
example  say my phone number is 9991234567
under the metadata section name-drop down i will select "ani" and enter the value as 999* or *999, will speech miner show calls starting with number 999?
thanks in advance
