Author Topic: Genesys Callback without ORS  (Read 1740 times)
Offline tech
« on: October 02, 2019, 10:38:10 AM »
Hello All,
Is it possible to use Genesys Callback  without ORS implementation? If not, could cassandra servers deployed for GMS nodes be used for ORS?
Thank you.
Offline David Alvarez
Re: Genesys Callback without ORS
« Reply #1 on: October 02, 2019, 10:47:23 PM »
You could use an Outbound campaign, inserting data to a dial-up list through the REST service that OCS.
This could be an alternative.
« Reply #2 on: October 04, 2019, 09:59:12 AM »
It can be used, but it depends on used version of GMS and ORS solution. Check available documentation or release notes for interoperability/supported version
Offline Raja Sekhar
  • Genesys Routing Applciation developer
« Reply #3 on: October 30, 2019, 09:30:01 AM »
to answer your question, GMS Callback needs ORS for sure, and Cassandra is not required for ORS in this scenario, Just GMS uses it.
