Author Topic: Xlite registration issue. - Lab  (Read 2055 times)
Offline kamalnba
« on: September 17, 2019, 11:14:44 PM »
Hi Folks,
I am registering Xlite to Gensys SIP server. I have exisitng sip server application-1 object associated with sip-1 installed on server. I have created DN(20001) in SIP-1 switch and able to register on Xlite.
I have created another SIP-2 application object and installed sip server in another directory of previous sip server. When I am creating DN(7001) under sip-2 switch it is not able to register and looks like request is going to Sip-1 and it is not able to find that DN.
Any help how I can achieve two sip server instances on same server with different SIP applications and switches?? I tried stoping and disabling SIP-1 in this case, I am getting 408 response.
Thanks.
Sent from my SM-G973F using Tapatalk
Re: Xlite registration issue. - Lab
« Reply #1 on: September 17, 2019, 11:55:50 PM »
Port conflict
Offline kamalnba
« Reply #2 on: September 17, 2019, 11:58:45 PM »
[quote author=Kubig link=topic=11440.msg52132#msg52132 date=1568764550]
Port conflict
[/quote]Thanks, On  SIP- 1, I am using 5065 and SIP- 5060 with same IP address. [emoji17] still problem persists.
« Reply #3 on: September 18, 2019, 01:00:33 AM »
Logs or never happened... Also, licenses, logs... We can't be guessing
Enviado de meu SM-G9650 usando o Tapatalk
Offline vmc
« Reply #4 on: September 19, 2019, 12:13:24 AM »
Where are you setting the port values?  Not using SIP Proxy?
Offline kamalnba
« Reply #5 on: September 19, 2019, 12:38:36 AM »
[quote author=vmc link=topic=11440.msg52138#msg52138 date=1568852004]
[/quote]Thank you. I sorted out the problem and able to register on SIP-2. Issue was fixed by stoping and disabling other sip server and removing IP address and port.
« Reply #6 on: September 20, 2019, 10:37:59 AM »
It does seems like permanent and systematic solution. I suppose to check your SIP Server configuration, there must be something wrong
