Author Topic: Disconnected from CFGInteractionServer 'conn-EmailServerJava_851-InteractionServ  (Read 1535 times)
Offline Tshwarelo
Gooday I am trying to set an email server but my issue is that is not connecting with interaction server it gives me this error
10:54:24.715 Std 29997 [ker.ixnsIvk] Connection to 'conn-EmailServerJava_851-InteractionServer_851' closed: [conn-EmailServerJava_851-InteractionServer_851@Gen-SRV1:7005] Error opening connection
com.genesyslab.platform.commons.protocol.ProtocolIOException: [conn-EmailServerJava_851-InteractionServer_851@Gen-SRV1:7005] Error opening connection
at com.genesyslab.platform.commons.protocol.DuplexChannel.wrapInProtocolException(DuplexChannel.java:236)
at com.genesyslab.platform.commons.protocol.DuplexChannel.onConnectionClosed(DuplexChannel.java:1703)
at com.genesyslab.platform.commons.protocol.DuplexChannel.access$900(DuplexChannel.java:79)
at com.genesyslab.platform.commons.protocol.DuplexChannel$DuplexChannelConnHandler.onConnectionClosed(DuplexChannel.java:1633)
at com.genesyslab.platform.commons.connection.impl.AbstractConnection$4.run(AbstractConnection.java:160)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.net.ConnectException: Connection refused: no further information: Gen-SRV1/192.168.107.152:7005
at sun.nio.ch.SocketChannelImpl.checkConnect(Native Method)
at sun.nio.ch.SocketChannelImpl.finishConnect(SocketChannelImpl.java:744)
at org.jboss.netty.channel.socket.nio.NioClientBoss.connect(NioClientBoss.java:150)
at org.jboss.netty.channel.socket.nio.NioClientBoss.processSelectedKeys(NioClientBoss.java:105)
at org.jboss.netty.channel.socket.nio.NioClientBoss.process(NioClientBoss.java:79)
at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:312)
at org.jboss.netty.channel.socket.nio.NioClientBoss.run(NioClientBoss.java:42)
... 3 more
Offline catanirex
Firewall?
Check if you can telnet to the port - if not, open the port in FW.
Offline Tshwarelo
ok thanks will ,will let you know if I win
