Author Topic: Business Process import failed  (Read 2027 times)
Offline gen_den
« on: August 27, 2019, 04:27:33 AM »
Hi All,
I am facing an issue while importing BP's in IRD. I always get below error:
[b]'Incomplete data, or the specified information is not within the allowable range'[/b]
I could not find anything in logs also nothing on Genesys KB.
can you please suggest what I can check further to fix this issue?
Re: Business Process import failed
« Reply #1 on: August 27, 2019, 03:34:22 PM »
Check CfgServer logs
Marked as best answer by ankush87 on August 28, 2019, 10:46:43 PM
Offline terry
« Reply #2 on: August 27, 2019, 05:11:38 PM »
Might be related with config server starting to reject by default empty sections.
Could try to set config server option skip-annex-validation to 1 to make it behave in compatible with older versions mode.
Offline gen_den
« Reply #3 on: August 28, 2019, 09:46:27 AM »
Thanks Terry it worked :)  :) :) :)
