Author Topic: How do you get interaction user data? WDE customization  (Read 2867 times)
Offline PFCCWA
« on: July 15, 2019, 11:52:37 PM »
I am trying to find the method to get a userdata key value from the interaction so it can be used to start a browser.
this is what I tried so far.
At the event ringing , WDE extracts the value of key ('URL_Field') and starts a browser ('http://www.genesys.com).
I have added a messagebox to confirm the value is extracted but that brings a blank response when call lands in WDE.
Tried a few other code snippets without success so not sure whether I am using an invalid method.
essentially I just want to take the key value and use it to start a browser in a new window.
[i][b]//…...
case EventRinging.MessageId:
                        // Do your processing here
                        var Url = string.Empty;
                        KeyValueCollection attachedData = interaction.AttachedDataInformation;
                        if (attachedData.ContainsKey("URL_Field"))
                            Url = attachedData["URL_Field"].ToString();
                        IWMessageBoxView.Show("Interaction Created: " + Url, IWMessageBoxButtons.Ok, MessageBoxIcon.Information);
                        System.Diagnostics.Process.Start(Url);
//…..[/b][/i]
thanks
Marked as best answer by PFCCWA on July 17, 2019, 04:09:30 AM
Offline PeteHoyle
Re: How do you get interaction user data? WDE customization
« Reply #1 on: July 16, 2019, 08:42:17 AM »
Try this:
            [code]
            if (interaction.GetAllAttachedData().ContainsKey("URL_Field"))
                return interaction.GetAllAttachedData()["URL_Field"] as string;
            }[/code]
Offline jamesmurphyau
« Reply #2 on: July 16, 2019, 09:13:23 AM »
GetAllAttachedData() is definitely the way to go
Offline PFCCWA
« Reply #3 on: July 16, 2019, 03:30:35 PM »
[quote author=PeteHoyle link=topic=11389.msg51938#msg51938 date=1563266537]
Try this:
            [code]
            }[/code]
thank you , worked like a treat.
This is the full portion of the code I used in the end after the EventRinging..
[i][b]//…...
                        Url = interaction.GetAllAttachedData()["URL_Field"] as string;
                        break;
//….[/b][/i]
