" /> The Recorder Integration Service has lost communication with IP Recorder - Genesys CTI User Forum
Author Topic: The Recorder Integration Service has lost communication with IP Recorder  (Read 5435 times)
Offline nhannt
Hi all,
I install Verint Recording on my lab
I just configure voice recording using Recorder Manager
however, it occur issue communicate between Integration Service and Recorders via internal NGA protocol
The both service : Recorder service and Recorder Integration Service still running on Recorder machine
I check Integration service log faced some error :
[NGAClient |3380|E] 2019-03-21 10:53:41.689+07:00  Failed to start <IFServices> NGA Client running on <10.15.15.43> port <29504>: java.net.ConnectException: Connection refused: connect
[GenesysSDK|2F9C|D] 2019-03-21 10:53:43.885+07:00  EventServerInfo received. Role<Primary:0>
[NGAClient |3380|E] 2019-03-21 10:53:46.713+07:00  Failed to start <IFServices> NGA Client running on <10.15.15.43> port <29504>: java.net.ConnectException: Connection refused: connect
[NGAClient |3380|E] 2019-03-21 10:53:51.705+07:00  Failed to start <IFServices> NGA Client running on <10.15.15.43> port <29504>: java.net.ConnectException: Connection refused: connect
[NGAClient |3380|E] 2019-03-21 10:53:56.697+07:00  Failed to start <IFServices> NGA Client running on <10.15.15.43> port <29504>: java.net.ConnectException: Connection refused: connect
[NGAClient |3380|E] 2019-03-21 10:54:01.713+07:00  Failed to start <IFServices> NGA Client running on <10.15.15.43> port <29504>: java.net.ConnectException: Connection refused: connect
Anyone please help if you have any idea to solve this issue.
Thank you so much,
