" /> Log4j2 and the LMS logging framework issue - Genesys CTI User Forum
Author Topic: Log4j2 and the LMS logging framework issue  (Read 2412 times)
Offline kellogs
« on: March 16, 2019, 10:40:36 AM »
I am new to Genesys altogether.
Has anyone succeeded with the new logging framework ?
I am having no luck with the [i]segments[/i] and [i]expire[/i] options. They just are not accounted for:
[code]KeyValueCollection logSection = new KeyValueCollection();
        logSection.addString("verbose", "all");
        logSection.addString("all", "logfile.log, stdout");
        logSection.addString("expire", "2 file");
        logSection.addString("segment", "1000 KB");
//        logSection.addString("log-file-size", "1000 kB");
//        logSection.addString("buffer", "false");
        KeyValueCollection logSection2 = new KeyValueCollection();
        logSection2.addObject("log", logSection);
        GApplicationConfiguration gaAppConf = new GApplicationConfiguration();
        gaAppConf.setOptions(logSection2);
    lmsMessageConveyor = LmsMessageConveyor.newBuilder().addLmsEnum(CommonLmsEnum.class).build();
    Log4j2LmsLoggerFactory.setLoggerFactoryImpl(Log.LOG_FACTORY_LOG4J2, lmsMessageConveyor);
    boolean mkay = Log4j2Configurator.applyLoggingConfig(gaAppConf, lmsMessageConveyor);
//    LmsLoggerFactory logFact = Log4j2LmsLoggerFactory.createInstance(lmsMessageConveyor);
//    LOG = logFact.getLmsLogger(AppManager.class);
    LOG = Log4j2LmsLoggerFactory.getLogger(AppManager.class);
//    lmsLoggerFactory = LmsLoggerFactory.createInstance(lmsMessageConveyor);
//    LOG = lmsLoggerFactory.getLmsLogger(AppManager.class);
//    LOG = LmsLoggerFactory.getLogger(AppManager.class);
//        PsdkCustomization.setOption(PsdkCustomization.PsdkOption.PsdkLoggerTraceMessages, "true");
        for (int i = 0; i < 25000; i++)
        LOG.info(CommonLmsEnum.GCTI_APP_INIT_COMPLETED);[/code]
This produces > 1MB of logs and the file just continues to grow instead of getting split at the1000 kB mark.
If instead of
[code]logSection.addString("all", "logfile.log, stdout");[/code]
I put
[code]logSection.addString("all", "logfile.log");[/code]
there is no more console output, so I know the settings are being applied. Tried with log4j2 versions from 2.7 to 2.11.2 - same thing.
Is this a know issue ? Should I go back to the deprecated logging framework instead ?
Thank you!
