" /> How to select an open WDE interaction by code? - Genesys CTI User Forum
Author Topic: How to select an open WDE interaction by code?  (Read 1986 times)
Offline DeonH
« on: March 10, 2019, 10:25:29 PM »
Hi
We have agents working on the WDE and they can receive more than one interaction at a time.
When a new Interaction Window is opened we have a browser component that is displayed on a new tab as part of the interaction.
The browser component sometimes sends an activate event that indicates that a specific browser component on one of the Interaction Windows needs to be visible.
Is it possible to:
- Get a list of open interactions
- Then make the corresponding interaction the active one via code. (Same as clicking on it in the top menu)
A pointer in the right direction would be appreciated
Thank You
Offline RobertH
Re: How to select an open WDE interaction by code?
« Reply #1 on: July 02, 2019, 01:03:15 PM »
Did you resolved this one?
