" /> Create Folder type Site - Genesys CTI User Forum
Author Topic: Create Folder type Site  (Read 3767 times)
Offline carpio
« on: August 15, 2018, 02:56:04 PM »
I'm trying to create a folder of type Site but get the error "No Permission to create object under this folder)
Here my test code:
CfgFolder folder = new CfgFolder(service);
folder.Name = "TEST";
folder.FolderClass = CfgFolderClass.CFGFCSite;
folder.Type = (CfgObjectType)22;
folder.OwnerID.DBID = ten.DBID;
folder.Save();
What am I missing?
Re: Create Folder type Site
« Reply #1 on: August 15, 2018, 04:04:27 PM »
The user you are using has no perm to create objects on that folder. Check it via CME first
Enviado de meu E6633 usando o Tapatalk
Offline carpio
« Reply #2 on: August 15, 2018, 08:41:02 PM »
Created a folder with my user in cme and it worked.
Did this first to make sure I use the correct values to create a site.
Offline terry
« Reply #3 on: August 15, 2018, 09:57:13 PM »
Shouldn't you also provide owner type and also may be parent's object type and DBID?
Offline carpio
« Reply #4 on: August 16, 2018, 01:00:26 PM »
For folders on top layer i usually never set the owner or parent.
I have tried to set this for the site folder but also no result.
I have tried to set the owner to tenant.
« Reply #5 on: August 16, 2018, 01:08:36 PM »
What does CfgServer logs say?
Try to compare a CME call VS yours
Offline carpio
« Reply #6 on: August 17, 2018, 08:42:13 AM »
I have compared the logs and saw that when i create a site folder in cme i have a ownerid
<CfgFolder
  DBID="0"
  name="TEST_CME"
  type="22"
  state="1"
  folderClass="2">
<ownerID>
  <CfgTenantOwnerShortcut
    linkDBID="1"  />
</ownerID>
<userProperties />
</CfgFolder>
Im now trying to set the owner id but i get always a error"object reference not set to an instance of an object"
my OwnerId is also null.
here is the code i try:
CfgFolder folder = new CfgFolder(func.app_service);
            folder.OwnerID.DBID = func.app_tenant.DBID;
            folder.Save();
Offline seaofwires
« Reply #7 on: December 04, 2018, 07:09:32 PM »
Posting this here for anyone else that runs into this problem.  I was able to fix the issue by assigning the folder.folderID value to the parent folder's DBID that I wanted to create the folder under.
Offline carpio
« Reply #8 on: March 05, 2019, 12:05:26 PM »
I have tried to set the folder id to the tenant but get a Exception that a required attribute was still missing.
CfgFolder site = new CfgFolder(service);
                site.Name = "Test";
                site.Type = CfgObjectType.CFGFolder;
                site.FolderClass = CfgFolderClass.CFGFCSite;
                site.FolderId = WellKnownDbids.EnvironmentDbid;
                site.Save();
Do I miss here something?
« Reply #9 on: March 05, 2019, 12:41:06 PM »
? Have you read the post above yours?
Enviado de meu SM-G9650 usando o Tapatalk
