Author Topic: Conference a call using WDE customization  (Read 2572 times)
Offline genesyslearner
« on: July 27, 2018, 11:08:27 AM »
Hi Experts,
We have a requirement in which we want to conference a call between agent and IVR through WDE customization. I am trying to build a custom command to achieve this feature but i am not getting any pointer if there is any  method available for conference in IInteraction Interface.
Any help on this topic would be great from you guys.
Re: Conference a call using WDE customization
« Reply #1 on: August 01, 2018, 11:55:14 AM »
What do want to exactly achieve (from your description it's not clear) - automatically make a conference for all calls or what is the goal?
« Reply #2 on: August 28, 2018, 01:18:55 PM »
Hi Kubig,
I am extremely sorry for the late reply.
Our requirement is when agent disconnects the call from WDE then the call should automatically be transferred to IVR instead of agent manually transferring the call to IVR.
So i want to built a custom command and set it on ReleaseCall so that there is no need to click the transfer button on WDE.
Offline hsujdik
« Reply #3 on: August 28, 2018, 01:36:46 PM »
Take a look if those other approaches don't help out... Maybe you don't even need to develop anything on WDE: http://www.sggu.com/smf/index.php/topic,11055.msg50251.html#msg50251
« Reply #4 on: August 28, 2018, 03:10:31 PM »
[font=verdana][size=2]after-call-divert-destination only works for SIP Server BTW[/size][/font]
« Last Edit: August 28, 2018, 07:46:58 PM by cavagnaro »
Offline rmartinez
« Reply #5 on: August 28, 2018, 06:34:11 PM »
You need use someting like this:
            this.commandManager.CommandsByName["InteractionVoiceReleaseCall"].Insert(0, new CommandActivator()
                CommandType = typeof(TransferCommand),
                Name = "TransferCommand"
For the transfer:
InteractionServiceExtensions.SingleStepTransfer(voiceService, Interaction, destination, "", UData, (KeyValueCollection) null, (KeyValueCollection) null);
i hope it will be useful
