Author Topic: MaxCustomValue  (Read 2652 times)
Fabio
MaxCustomValue
This is my problem:
I ha to get the max value og busy places in 1 hour. I try to get it using the MaxCustomValue and custom formula but i havn't any results. Ia use a straqtegy the attach a data containing the current busy place value. Someone can help me please? thank you.
DR00PY
MaxCustomValue
  • What the definition you are using?
    Fabio
    MaxCustomValue
  • This is my statistic definitio:
    [CurrentMaxBusyPlace]
    Objects=Agent, Place, GroupAgents, GroupPlaces
    Formula=GetMax("FreePlaces")
    Subject=DNAction
    MainMask=*
    Category=MaxCustomValue
    Is seems doesn't work. Probabilly i don't use in right way or it is wrong. Do you have the solution? Thank you so much. Bye.
