" /> IWS BundleClose Command have null reference to EntrepriseInteractionCurrent - Genesys CTI User Forum
Author Topic: IWS BundleClose Command have null reference to EntrepriseInteractionCurrent  (Read 2225 times)
Offline gogupandele
Hello everyone,
Unfortunately I have to debug an issue that occurs in an instance of IWS 8.1.
I have a custom command that is configured to execute before BundleClose / Close like this:
[code]commandManager.InsertCommandToChainOfCommandBefore("BundleClose", "Close", new List<CommandActivator>
                    new CommandActivator
                            CommandType = typeof(BundleCloseCommand),
                            Name = "BundleCloseCommand"
                });[/code]
Everything is great, this gets executed but in that custom command I have a piece of code that suddenly (from something like 2-3 weeks ago) started to generate a NullReferenceException. While doing the debugging I realized that the issue is coming from this piece:
[code]
IInteractionsBundle bundle = parameters["CommandParameter"] as IInteractionsBundle;
IInteraction mainInteraction = bundle.MainInteraction;
string id = mainInteraction.EntrepriseInteractionCurrent.Id;
[/code]
The last line is the one that throws the exception and it seems that in my case EnterpriseInteractionCurrent is null and I have no idea why.
Please, is there someone who can point me in any kind of direction or give me a hint?
I don't know if it counts or not, but it seems that the maineInteraction is actually a IInteractionPullPreview (Genesyslab.Desktop.Modules.Outbound.Model.Interactions).
Thank you very much.
Offline RobertH
For pull preview interaction is enterprise interaction current not always working well.
I'm not sure in what cases is the enterprise structure created or not. I was having issue obviously in early interaction create stages (e.g. view conditions), the enterprise structure was sometimes null, sometimes not null. Maybe it depends from PC performance, I have no clue.
if you want to read just interaction id, do it like this:
interaction.GetAttachedData("InteractionId");
this is rock solid. (Means mostly working eservices and open media interactions) :-)
