" /> WDE - update text in notepad - Genesys CTI User Forum
Author Topic: WDE - update text in notepad  (Read 2349 times)
Offline bharath
« on: December 05, 2017, 07:44:49 AM »
Can any one help how to update the text in notepad (using notepadviewmodel).
thanks in advance.
Offline PeteHoyle
Re: WDE - update text in notepad
« Reply #1 on: December 06, 2017, 10:25:40 AM »
Depending on how and where you want to update the text in Notepad the best place to start would be to get the interaction and then use the code below:
[code]                            INotepadViewModel notepadViewModel = inter.UserData.TryGetValue("NotepadViewModel") as INotepadViewModel;
                            if (notepadViewModel != null)
                                notepadViewModel.Text = "My Text";
                            }[/code]
