Author Topic: How to hide Call Result pull-down menu  (Read 3264 times)
Offline Ali
  • Haunted by Genesys
    • My Web Site
« on: November 06, 2017, 10:24:01 AM »
Working on an IWS-related Project.
When we are to conclude a preview call, we have disposition codes displayed on the Interaction Window. What I want is to Show disposition codes as Call Result pull-down menu is not visible to user.
In my code,
[code]if(_viewManager.ViewsByRegionName["InteractionDetailsRegion"] != null)
                foreach(ViewActivator view in _viewManager.ViewsByRegionName["InteractionDetailsRegion"])
                    if(view.ViewName == "DispositionsView")
                        // view.ViewType = null;
                        IDispositionsView MyView = view.ViewType as IDispositionsView;
                        break;
            }[/code]
So, I have two questions:
1. Can I have retrieve the object reference to Call Result pull-down menu?
2. (AND/OR) Is there a way to disable/hide Call Result pull-down menu?
Thank you in advance and best regards,
Ali
Re: How to hide Call Result pull-down menu
« Reply #1 on: November 06, 2017, 11:44:13 AM »
Under roles, isn't there an option for that?
Offline hsujdik
« Reply #2 on: November 06, 2017, 12:40:22 PM »
[quote author=cavagnaro link=topic=10732.msg48780#msg48780 date=1509968653]
Outbound - Can Set Call Result
https://docs.genesys.com/Documentation/IW/latest/Dep/OutboundCampaignPrivileges
You can disable editing, but not disable displaying it
Offline PFCCWA
« Reply #3 on: September 06, 2018, 10:45:47 AM »
We are still using GAD (v76).
Is there an option to disable it on this component?
We are using the agent scripting (v81) for agents to complete however it is still possible to mark done a record using the original call result field - which we want to stop.
thanks
Offline hsujdik
« Reply #4 on: September 06, 2018, 12:40:11 PM »
Does the outbound contact server "record_processed" = false option suite your needs?
https://docs.genesys.com/Documentation/OU/latest/Dep/OCSOptionDescriptions
Offline PFCCWA
« Reply #5 on: September 07, 2018, 11:41:47 AM »
no it does not as the agent cannot complete the record after the call has been released.
thanks
