Author Topic: Sending KeepAlive message to TServer  (Read 1960 times)
Offline Gabi
« on: October 19, 2017, 01:47:29 PM »
Hello. I was wondering if you could help me with this.
I need WDE to send KeepAlive messages to a TServer. I don't know if there is already a configuration option which enables WDE to do this (if there is, I have not found it), or if it should be done with either PSDK or Enterprise SDK and, if so, how.
All I have right now is an excerpt from a log in which one such message was sent.
[code]message EventUserEvent
            AttributeEventSequenceNumber      00000000001ad553
            AttributeTimeinuSecs            518000
            AttributeTimeinSecs  1507647650 (12:00:50)
            AttributeUserEvent    EventUserEvent
            AttributeAgentID        '9200'
            AttributeThisDN        '541143357300'
            AttributeUserData      [34] 00 01 00 00..
                        'GSW_AGENT_REQ_TYPE'      'KeepAlive'
            AttributeServerCapabilityMask        [64] ff ff ff ff..
            AttributeReferenceID  6[/code]
Assuming I need to build a RequestDistributeUserEvent, I can see what the User Data needs to be, and I believe I can find the DN and the agent ID (I'm assuming it's the Employee ID), but I don't know what the sequence number, times, capability mask and reference ID should be.
Any help will be appreciated.
Re: Sending KeepAlive message to TServer
« Reply #1 on: October 20, 2017, 07:54:19 AM »
For what purposes do you need the "keep-alive"? There is built-in mechanism which can be used for this purpose (ADDP)
