Author Topic: PSDK Add\Remove AgentLogin from Person  (Read 2784 times)
Offline carpio
« on: September 29, 2017, 07:37:56 AM »
here I'am again :)
I want to add or remove a AgentLogin to a person but do get an error when running this code:
var login = func.agentlogin_query("1234").SingleOrDefault();
            var person = func.person_query(login.DBID).SingleOrDefault();
            CfgAgentLoginInfo info = new CfgAgentLoginInfo(service,person);
            info.SetAgentLoginDBID(login.DBID);
            Console.WriteLine(info.ToString());
            person.AgentInfo.AgentLogins.Add(info);
            person.Save();
I get this error:
{"Object reference not set to an instance of an object."}
The extension exists and the console write is giving me this result:
CfgObject type = Genesyslab.Platform.ApplicationBlocks.ConfigurationObjectModel.CfgObjects.CfgAgentLoginInfo
properties :
    agentLoginDBID : 111
Can anyone help?
What I'm doing wrong?
« Last Edit: September 29, 2017, 07:40:17 AM by carpio »
Offline PeteHoyle
Re: PSDK Add\Remove AgentLogin from Person
« Reply #1 on: September 29, 2017, 09:29:03 AM »
For me that worked.
Below is the modified slightly to retrieve the CfgAgentLogin and use that when creating the CfgAgentLoginInfo object, but even using your way of using .SetAgentLoginDBID worked.
[code]                    CfgPersonQuery qPerson = new CfgPersonQuery();
                    qPerson.UserName = "phoyle";
                    CfgPerson myPerson = confService.RetrieveObject<CfgPerson>(qPerson);
                    if (myPerson == null)
                        log.Info("Person Not Valid");
                        return;
                    CfgAgentLoginQuery qLogin = new CfgAgentLoginQuery();
                    qLogin.Dbid = 422;
                    CfgAgentLogin myLogin = confService.RetrieveObject<CfgAgentLogin>(qLogin);
                    if (myLogin == null)
                        log.Info("AgentLogin Not Valid");
                        return;
                    CfgAgentLoginInfo agentInfo = new CfgAgentLoginInfo(confService, myPerson);
                    //agentInfo.SetAgentLoginDBID(422);
                    agentInfo.AgentLogin = myLogin;
                    myPerson.AgentInfo.AgentLogins.Add(agentInfo);
                    myPerson.Save();[/code]
Offline carpio
« Reply #2 on: September 29, 2017, 10:19:40 AM »
I saw my mistake when adding the number, I have searched for the agent who got the agentlogin assigned.
so adding is now woking aswell.
Just removing is still not working:
var login = func.agentlogin_query("1324").SingleOrDefault();
            CfgAgentLoginInfo info = new CfgAgentLoginInfo(func.app_service, person);
            person.AgentInfo.AgentLogins.Remove(info);
            person.Save();
Offline PeteHoyle
« Reply #3 on: September 29, 2017, 12:39:58 PM »
You could make a method based on this code to remove the Agent Login:
[code]
                        return;
                    CfgAgentLoginInfo loginToRemove = null;
                    foreach (CfgAgentLoginInfo loginInfo in myPerson.AgentInfo.AgentLogins)
                        if (loginInfo.AgentLogin.LoginCode == "0001")
                            loginToRemove = loginInfo;
                    if (loginToRemove != null)
                        myPerson.AgentInfo.AgentLogins.Remove(loginToRemove);
                        myPerson.Save();
[/code]
Offline carpio
« Reply #4 on: October 02, 2017, 12:54:07 PM »
Thanks PeteHoyle, with you code its working fine.
I have to modify it a bit but for now its working.
Big Thanks
