" /> Get current ConnID from Interaction - Genesys CTI User Forum
Author Topic: Get current ConnID from Interaction  (Read 2284 times)
« on: September 25, 2017, 03:47:35 PM »
Hi guys
Having a situation here.
PSDK C#
I need to get the current connID of an interaction. I am developing a software which monitors a few DNs. The idea is that a supervisor can release a call (by business model) at any time.
Do I need to monitor the events of each DN to get the ConnID for the current call on each Event or is there a way I could just query the ConnID of a DN at any moment to send the RequestReleaseCall?
Offline hsujdik
Re: Get current ConnID from Interaction
« Reply #1 on: September 25, 2017, 04:28:52 PM »
RequestQueryAddress might do the trick (you can even do that on the TestPhone on the Query tab to see how the output comes - EventAddressInfo). You don’t even need to be registered to the DN to perform the RequestQueryAddress (although you’ll need to be registered to send the RequestReleaseCall)
Offline Gabi
« Reply #2 on: October 19, 2017, 01:54:48 PM »
Do you have an IInteraction object? If you do, you can get the ConnID like this:
interaction.EntrepriseLastInteractionEvent.ConnID.ToString()
« Last Edit: October 19, 2017, 01:57:16 PM by Gabi »
« Reply #3 on: October 19, 2017, 01:58:13 PM »
Thanks guys, got it.
Just to mention that the connid in the PSDK is always capital letters and TServer uses lower ones...so be careful with that.
