" /> Duplicate interacions when searching UCS with PSDK RequestSearch - Genesys CTI User Forum
Author Topic: Duplicate interacions when searching UCS with PSDK RequestSearch  (Read 2899 times)
Offline ricardo.sosa
I am performing a query to UCS using RequestSearch and some conditions. For example:
[code]
RequestSearch req_search = RequestSearch.Create();
req_search.MaxResults = 100;
req_search.Query = "SentDate:[2017-04-01T00:00:00 TO 2017-05-07T23:59:59] AND FromAddress:*xxx.xxx* AND TypeId:"Inbound"";
req_search.IndexName = "interaction";
IMessage res = protocol.Request(req_search);
[/code]
The thing is that I get several interactions with the same ID. I would like to get only one record for each ID, the most recent one.
Is there any way to acomplish this?
Thanks.
Ricardo.
Re: Duplicate interacions when searching UCS with PSDK RequestSearch
« Reply #1 on: August 21, 2017, 01:15:37 PM »
Reindex the index files on UCS level from scratch (by related option on UCS application level)
« Reply #2 on: August 21, 2017, 03:49:54 PM »
Thank you Kubig,
I will check with the administrators if they can do it.
Thanks.
« Reply #3 on: August 22, 2017, 07:38:44 AM »
If they know Genesys, they will be able to do that. It is general function of UCS component - so, just configuration change and restart, nothing else.
« Reply #4 on: August 25, 2017, 08:21:27 AM »
They did this reindex and it looks like it is working!
Thank you very much  :)
Ricardo.
« Reply #5 on: August 25, 2017, 08:48:20 AM »
You are welcome, I am glad it helped!
